440 timing
440 timing
i bumped the timing up to 15 degrees advanced at idle, and the car runs better all around
i only use 93 octane with around 10.3 - 1 compression
can anyone give any insight to why the engine never pings
X2
the higher octane helps to keep it from pinging. If you go with 89 or maybe even 91 octane, it could start to ping. the higher octane burns longer and helps to prevent pre-dentanation (i'm pretty sure).
I think the factory was kinda conservative with the timing as far as the specs. go for that very reason. Remember, these things were used for everyday transport back when they were new. So lets say that back in 67 you went for a trip somewhere out of state and the gas station was out of everything except 87. Youre not gonna wait around for the good stuff to get there, no you put in the 87 and go down the road. there was kinda a saftey margin. Example two: some old lady that ended up with a GTX for some reason. {you know it happened} she would be less likely to shell out for the high octane gas.
But, you have to be careful because there can be "pinging" that is almost impossible to hear. The old racers used to be able to tell if there car was pinging [detonation] by reading the spark plugs. It takes a teally keen eye though, really good eyes 'cause the clues are hard to see.
An idea I had was to use knock sensor [from a newer car] and listen to my engine for detonation or preignition and use a pair of head-phones to listen to the engine while I am driving.[ but I aint figured out just how to make it work yet.]
No you can not always hear all of the pinging. That is why it is best to stay on the safe side. Sometimes you can feel it more than you can hear it. Feels like a mild hesitation but only at certain rpm's.
I guess the basic rule is 10 octane per 1 compression ratio. Like if you had 9.5 to 1 than you would use 95 octane to be safe but that is just a basic rule that has no connection with real world situations.
well, the car didnt seem to hesitate at all
it really seemed to have better throttle response, and it even started easier
but, i am surprised that with the increase in timing, that the car starts easier
usually, the opposite happens
This is how I like to set my initial timing. I crank up the timing til it is hard starting than I back it off til it turns over like I think it should. Usually im at 12-15 degrees initial. Most time I gotta limit the total advance {welding involved} when the initial is at 15+. Then ill put some stiffer advance springs to limit the pinging with the gas that I use. you can do the opposite with good gas.{lighter springs}. This is all cheap "street racing" stuff that I used to experiment with back in the eighties {i'm old fart}. 67 belvedere with 383 and 72 demon with 318 back then.
Matt -
Might want to get an idea of what your total advance is as well. The BB's generally don't need or like the vacuum advance, and even with 15 initial, you may or may not be reaching 32 total, IIRC that's about where most mild BB's like to be. Just a thought.
If the car is behaving better at 15, I wouldn't sweat it too much. just make sure that there aren't any of the usual "oops".
Archer.
Archer.
What is your total timing? That is what is important. I would think with 93 octane you should be able to have a total timing of about 38 degrees full advance.
These knocks are actually high frequency vibrations caused by detonation, or the premature burning of fuel inside the engine's cylinders.
___________________
Knock Sensor Function
___________________
Vacuum advance will make a big difference in gas mileage !!! It should be hooked up on street car. There are some that can be adjusted. SO you need to figure out what is in the distributor.
Get your initial 15 Plus 23 in the distributor for 38. With the vacuum advance 48 to 52 total
a.johansson84
May 27, 2012 03:30 AM
