440ci RV engine
Old Feb 23, 2009 | 11:26 PM
crmzendrgone's Avatar
440ci RV engine
My friend just confused the heck out of me, he said that the 440 engines that were put into RVs are wider than the 440s used in the passenger cars, he also said that water runs through the heads as the others don't because the loads the engine has to deal with in the RV it needs more cooling. It is my understanding that all engines have coolant running through the heads. Last he said that some of the 440s had steel cranks in them and that they are more valueable and some have "other" metal cranks, again i thought that all cranks are made of steel. Is any of this true? because i have no clue?
Old Feb 24, 2009 | 02:20 AM
Next time you see your friend, slap him/her on the back of the head for all of us.
All Mopar cylinder heads have coolant running through them since that is where a lot of the heat is created. If they didn't, then they would warp, crack, leak, etc.
Some 440s had steel cranks while others had forged cranks. The forged cranks are stronger. Steel is a metal so all cranks are made from a metal.
Lets recap:
Slap friend on back of head.
All mopar heads run coolant through them.
440 cranks are either steel or forged.
Hope this unconfused you.
Old Feb 24, 2009 | 02:28 AM
Polaradude's Avatar
I would follow Tim's educational flow chart for your friend.
Old Feb 24, 2009 | 08:10 AM
To good, to good LOL. sounds like an easy chart to follow. is it true about the 440 RV engines being wider or is that BS.
Old Feb 24, 2009 | 08:44 AM
Over all wider with the exhaust manifold? Maybe
Wider as in just the engine and heads? I highly doult it.
Old Feb 24, 2009 | 09:15 AM
Why might want to ask him why freeze plugs are installed on ALL heads also. Along with why ALL heads have water passages through them.
Old Feb 24, 2009 | 09:51 AM
Polaradude's Avatar
Now that's just crazy talk.
Old Feb 24, 2009 | 01:23 PM
haha
too much
Old Feb 24, 2009 | 11:18 PM
You guys are great, you have me laughing. I appreciate the insite about all this. THANKS!
Old Feb 24, 2009 | 11:34 PM
rr69half6bbl's Avatar
this proves that a person with a little info can be very dangerous, your frind was a little correct. the winabegos in the early 70`s had 440`s in them no the heads werent bigger, however, the heads did have water ports at the front for the pump housing, instead of running colant through the passages in the block they ran them through the heads themselves for better coolant flow. if you ver see a head that has round caps on the front of the heads with 2 bolts holding the cap on thats a winnie head.On the up side.the blocks are still the same. on the crank deal. all the cranks from ma mopar were steel untill 72. then for 73 they were all cast , cast cranks are a thinner cheaper material. so it was more cost effective. yes the steel crks. are more valuable, but you can use a cast crank up to 600 horse and not have any problems. its mostly a personal pref. thing.Oh yeah, indeed slap the guy on the head, but give him a hug when he starts to cry . it wont make it so bad on him.LOL
Old Feb 24, 2009 | 11:45 PM
Awesome, awesome. Thanks for getting me straightened out. so i quess he half knew what he was trying to say about the water ports and the cranks. I will give him a good slap and then a even bigger hug it might surprise him that i would slap him. LOL
Old Feb 24, 2009 | 11:53 PM
sweeeeeeeeeeeeet now your on to something
Old Feb 25, 2009 | 04:48 PM
haha
Old Feb 25, 2009 | 11:54 PM
All this talk about cast, steel and forged cranks make me wonder how one can tell the differnece. Are there casting numbers or distinguishing marks that say what kind it is?
Old Feb 26, 2009 | 03:07 AM
Polaradude's Avatar
On most motors you can tell by the harmonic balancer, if it has weights welded to it its externally balanced and this is a cast crank on the inside and if there are no weights on the balancer the engine is internally balanced which is a forged crank. Maybe someone can explain this better than I. Also decoding the #'s will tell ya also.
Old Feb 26, 2009 | 05:18 AM
Commando's Avatar
If you look at the picture that is a steel crank, I do not have a picture of the cast crank I pulled out but the steel one is rounded, and the cast one is squared out.
Old Feb 26, 2009 | 06:50 AM
And here I though all cranks were round so that they could spin.
(sorry, couldn't help myself)
Old Feb 26, 2009 | 09:17 AM
Commando's Avatar
Nice, well so you are saying square wheels are a bad idea?
Is blocked out a better term to reduce confusion.
Old Feb 26, 2009 | 09:22 AM
they are not a bad idea...... they just work better on vehicles that I am run against.
Old Feb 26, 2009 | 03:52 PM
Polaradude's Avatar
Does anyone have the part # for these performance square wheels. Are they Foose?
Old Feb 26, 2009 | 04:32 PM
BuckNeccid's Avatar
The forged balancers are only about 1" thick, the cast balancers are way thicker, it's an obvious difference.
And am I wrong, or don't all the RV cranks have 8 bolts for the flywheel?
And if you plan on using one in a car, plan on changing the oil pan and pick up. The RV generally uses one with a rear pick up and sump, the car has a mid pickup and sump.
ProEmaster
Jun 6, 2007 11:31 AM
