6 pack questions
Old Aug 10, 2009 | 02:28 PM
Crazy4Carz.Com's Avatar
You are not going to find a "bolt on" set up for the application you are putting together. Hot rodding always means having to improvise. Everyone that has done this, has done the same thing, make it yourself. Good luck! You can do it!
Old Aug 10, 2009 | 02:31 PM
Oops, I forgot, you are going to have a problem with the kickdown cable as well. This is important. DO NOT drive without the kickdown in place and working correctly. Lokar (the shifter people) have a cable for this. Yes it is expensive.
Old Aug 10, 2009 | 05:25 PM
scotts74birds's Avatar
Found this. May help, may not. Seems like good tuning info http://www.mopar1.us/6barreltips.html
Old Aug 17, 2009 | 02:29 PM
Great, I knew Lokar had the kickdown, I didn't know they had the throttle. As a Universal kit there will be some modding. As I said they are expensive, I think once you see the kit you will find you could have made something else yourself for much less money. Good luck.
98 SNAKE EATER
Apr 16, 2013 05:56 PM
440beep
Jul 19, 2012 07:26 PM
MoparMan76
Jan 14, 2011 01:31 PM
richk2843
Jun 21, 2008 11:29 PM
nixtreez
Apr 4, 2008 04:28 PM
