63 Savoy Head light switch schematic
Old Apr 15, 2012 | 02:11 PM
MW Savoy's Avatar
Does anyone have a schematic/drawing for a head light switch? I've got everything nailed down but the B1 terminal but I would like to make sure what I have already is correct.
Old Apr 15, 2012 | 05:16 PM
Useable diagrams are available at "MyMopar"
http://www.mymopar.com/index.php?pid=26
http://www.mymopar.com/downloads/196...rySavoyV8A.JPG
http://www.mymopar.com/downloads/196...rySavoyV8B.JPG
The light switches are somewhat of a trick, they have essentially 4 switches in "the box."
HEADLIGHT switch -- this circuit is fed UN fused power off the so called "in harness splice" coming from the ammeter circuit
TAIL/ PARK fed from the fuse panel
dash dimmer control
and the dome light switch, which GROUNDS that circuit to activate
Look at diagram "A"
Along the top, you have
TAN is the output of the dash dimmer control, and is supplied from the tail light circuit. TAN feeds this power out to a special fuse in the fuse panel, changes to ORANGE, and feeds all the dimmer controlled dash lamps
LT GREEN Headlight power out to the dimmer switch
BLACK tail light power out to the rear
BLK (large gauge) UN fused power coming TO the headlight circuit from the "in harness splice"
Along the bottom, you have
YELLOW ground side of the dome light circuit, also goes to the door switches
PINK power FROM fuse box for the park and tail, dash lights
YELLOW / TR output to front parking lights. NOTE on later cars which hold park lights on with headlights, ALL Ma did was to move this wire over to the tail light power (small gauge black)
70plumchallenger
Aug 11, 2015 08:26 AM
CaptBeach
Dec 17, 2013 05:26 PM
mr.300
Feb 12, 2012 11:33 AM
Norskinder
Oct 13, 2011 11:19 PM
chiefgtx
Sep 26, 2009 12:07 AM
