'65 belvedere wont start after use
Old Jun 22, 2009 | 11:14 AM
It could be your starter relay or your starter is getting hot and cutting out. I would jump the relay and see if it starts while it is at operating temperature. If it does start, then replace the relay.
Old Jun 22, 2009 | 11:25 AM
could it be vapor lock?
Old Jun 30, 2009 | 02:08 PM
64fury's Avatar
Belvedere1965
Any update on your issue, were you able to fix it? was it the relay or vapor lock? Just curious as my Fury does that sometimes, starts fine the first time, but is harder to start (but will start) when hot, unless it sits for 20 min or so, then it starts just fine!
Old Jun 30, 2009 | 02:22 PM
Crazy4Carz.Com's Avatar
Vapor lock is gas boiling and turning to vapor in the lines/filter/bowls. Won't affect the starter.
Old Jun 30, 2009 | 05:08 PM
Polaradude's Avatar
Try some header wrap around your starter, sounds like heat bog to me.
Old Jul 2, 2009 | 08:58 AM
Mopar_71's Avatar
It could be a number of things.
But, since it sounds like the starter is functioning properly. The original post says it's NOT clicking. That is the sound of a dead battery.
It seems the engine is turning over just not starting up.
We need to focus on electrical igintion and fuel delivery.
When the engine acts up like this again, grab a spare spark plug or take one out of the cylinder head and plug it into one of the plug wires. Remember to put the spark plug next to a thick metal object like your exhaust manifold so you can create an arc.
With a buddy trying to start your engine watch the spark plug.
If you see no sparking, you have an electrical problem.
If you see spark, you have a fuel problem.
Let us know what you have and we can go from there...
Good luck.
Mopar_71
davidegruber@comcast.net
Mar 18, 2011 06:39 PM
6865coronet
Aug 11, 2009 09:55 PM
shelbydz
May 9, 2009 03:10 AM
duster74
Feb 11, 2009 07:43 PM
dodgeaspenrookie
Jul 18, 2008 07:28 PM
