70 RR dash dimmer
Old Sep 6, 2011 | 02:00 PM
rrdoug's Avatar
70 RR dash dimmer
I have no dash light all of a sudden.I think its the dimmer switch.I heard you can bypass the dimmer part and have them on all the time but are they still avalable from auto parts stores???
Old Sep 6, 2011 | 02:22 PM
I have no idea where you can get them, anymore, but it is basically two functions in one
A switch for the dome / courtesy lamps
A series variable resistance for the instrument lamps brightness control
So, yeah, you could pull it out, the tan is the feed to the instrument lamps. You'll have to probe with a test lamp, parking lamps on/ off to find which wire controls that power, and make a temporary jumper to hook them together.
Frankly, after you get it out, I'd spend a little time with it. There's not much to it, it's a wirewound resistor, and the **** moves a "wiper" contact around it. Might just be dirty/ corroded, or the connector loose/ dirty/ corroded.
Old Sep 6, 2011 | 05:57 PM
fivepoint's Avatar
I see them on E-Bay once in a while. They are advertised as reconditioned. Mine has a couple of dead spots as I rotate it. The next time I remove the switch panel, I am going to clean in it up to see if it helps.
Old Sep 6, 2011 | 06:54 PM
John Van's Avatar
Here's a guy who rebuilds them, great work!http://www.julesdaddio.com/index.html
cuda101
Oct 1, 2014 07:50 PM
hmiller79
Oct 8, 2008 02:58 AM
ccflash22
Nov 20, 2007 03:08 PM
Dartin'
Nov 10, 2007 03:32 AM
buddahluvaz
Apr 20, 2007 07:37 PM
