727 or 904?
Old Dec 6, 2008 | 07:46 PM
challenger's Avatar
easyiest way is by the pan on the bottom 727 is some what L shaped and the 904 is more square
Old Dec 6, 2008 | 10:11 PM
rr69half6bbl's Avatar
If they came from behind a big block theyre 727`s, you didnt get a 904 w/ big blocks, if the driveshaft yoke that fits into the back of the trans is a small diameter, will easily fit in your hand its a 904, if it barley fits in your hand its a 727.
Old Jan 9, 2009 | 04:37 AM
Polaradude's Avatar
Originally Posted by CLJohnny
I have a pair of transmissions, how do you tell if they're 727 or 904?
John
Measure them from stem to stern, if you are having trouble, the 727 should be 35"
Old Jan 9, 2009 | 06:23 AM
Originally Posted by 66sportfury
no its not hard to switch at all, just swap them out and go to a wrecking yard and get yoke. 727 is a much stronger tranny. gl
That can be debateable. While the 727 has many more performance parts for it, the 904 can be built up just as strong as the 727, it just costs more to do it and the parts are harder to find.
norcalitwin26
Jun 5, 2014 02:16 PM
captaindanger
15
Mar 20, 2014 09:26 PM
michuy
Nov 24, 2013 11:30 AM
blue 68 gts
May 25, 2012 09:10 AM
66FuryBoy
Mar 14, 2011 02:55 PM
