727 Conveter help
Old Feb 11, 2011 | 09:03 PM
Cazbah362's Avatar
727 Conveter help
OK, I have a 1966 727 which has been rebuilt but needes a new converter. I have a 1972 413 which was pulled from a motorhome that had a 727. I kept torque converter from the 413/727 however I am not sure if I can use the torque converter on the 1966 transmission? The 413 has the flex plate. I was told I needed a 090 converter for the 1966 transmission. How do you tell which converter is which. Attached are the photos of the 1972 converter and the 1966 transmission.
Can I pair the these two together without any issues. Any othere thoughts?
Old Feb 19, 2011 | 05:55 PM
bboogieart's Avatar
I would think not, but if the motors are both internal or external balance it will work. you might want to put a 73 or new part throttle kick down in that 66. It helps a lot with daily driving. I assume the 66 has a 66 big block in it? It will help to have more info.
Old Feb 19, 2011 | 07:01 PM
blue 68 gts's Avatar
It should work, you might just need a diff flex plate.
I'd also go with a manual valvebody instead of kickdown linkage..
Old Feb 19, 2011 | 07:39 PM
MercuryDon's Avatar
You need to make sure the converer is balanced for the rotating assbly you are using. The are to my knowledge 3 differant ones.
1. Small Rod Steel crank Small square edged damper
2. Large Rod Steel Crank Large Square Edged Damper
3. Cast Crank. Large Beveled Damper
Old Feb 20, 2011 | 08:02 PM
Cazbah362's Avatar
Thanks for the help
Going to use the 413 with this 1966 transmission - this is the same 413 I pulled it out of with the motor home transmission, so it should all be balanced to the motor, flex plate and balancer etc.... Was concerned, never heard of a 090 converter, but theres a lot I have never heard of, so learned better to ask. I really appreciate all the insight. As for manual valve body and such. Doing this on the cheap, already have more into the 413 and trans than I wanted. I have the kick down that came with the 72 trans, plan on using it - thanks for the insight. And actually this mess - 1972 413, 1975 975 heads, Mopar Purple Cam and 1966 727 are going into a 1967 Belvedere. Attached is a photo of the motor
Old Apr 8, 2011 | 03:25 AM
Locar ? makes a nifty kickdowwn cable
64fury
Jun 14, 2016 07:15 PM
pipdog69
Mar 13, 2012 11:01 PM
anthony oborny
Jan 10, 2010 06:06 PM
mopar nate
May 18, 2009 02:16 AM
george buscemi
Apr 6, 2008 01:35 PM
