73 charger ignition problem
Old Sep 24, 2010 | 01:11 PM
rcross's Avatar
I can start the engine but can not turn it off. It just keeps running as if nothing happened. I have replaced just about everything. There is no power in the yellow wire coming into the ignition relay on the the firewall which I understand shuts the engine off when the key is turned off. I tried another ignition switch from my parts car and the same thing happened. I would really appreciate some suggestions.
Thanks, R
Old Sep 24, 2010 | 02:35 PM
Archer's Avatar
r -
OK, no idea. I assume you replaced the ignition relay as well? If not, is it possible it or the wires going through the firewall are shorting?
Welcome to the board, wish I could be of more help.
Old Sep 26, 2010 | 08:58 AM
rcross's Avatar
Archer,
Thanks for the reply. I found the problem(s). The hot wire to the dash was fried and the clip to the ignition module was not connected well. Now I have a big mess to take care of. My next post will be under "need wire diagram".
r
Plymth74Dstr
Dec 21, 2013 07:17 AM
a.johansson84
May 27, 2012 03:30 AM
jls
Feb 6, 2011 09:52 PM
Tiretrack
Jul 10, 2010 08:14 PM
GMdude
Jul 9, 2009 04:42 PM
