78 Dodge B300 Motorhome Electrics
Old Jun 25, 2016 | 04:23 PM
gbm97's Avatar
Ok I bought a 12 volt in dash stereo which I installed in the motorhome end of my 1978 Dodge Sportsman.
What I did
Removed a wall mounted 12 volt light fixture.
Using the pos & neg wires from the removed light fixture I hooked up to the stereo.
Problem
Upon connecting the wires properly the rest of the motorhome lights dim way low. Also a small spark upon connection.
I hooked the stereo into the dash of the cab and it worked fine. No spark...no draw.
So something about running the stereo through the motorhomes converter system is the cause.
Any ideas?
Thanks
edit:
Solved that. Black is live White is ground out of the converter.
I had it backwards.
Last edited by gbm97; Jun 25, 2016 at 08:28 PM. Reason: Solved with no delete button
Old Jun 26, 2016 | 06:22 AM
Run a Better Battery + wire and a Ground - wire.... Most of those light grounds are not all that great.... String some new wire for the radio...
Just my 2 cents. Keep us posted on what you fine !!!!
heminate
Aug 18, 2019 03:06 PM
patsquatch
Jul 26, 2012 02:29 AM
ernzo2
Oct 4, 2011 05:27 PM
birds
Mar 7, 2010 08:28 AM
TimN8er
Nov 30, 2009 01:28 PM
