A833 bell housing
Old Dec 7, 2010 | 05:42 AM
teedeej340's Avatar
A833 bell housing
I have a aluminum bell housing for a A833 which would have been off a 74 E-body (#3743859). Can I use this in a 68 A-body without too much trouble? Or does it have more to do with the A833 year?
Old Dec 7, 2010 | 09:15 AM
All A833's have the same bolt pattern to my knowledge, the DIFFERENCE comes in that some --specially the 18 spline--have a larger bearing retainer therefore bellhousings can have different size center holes
(Having said that, there does exist some A833 OD transmissions drilled for GM, I can't recall if they made 'em for Ferd 'er not. The GM OD unit I saw also had a special GM style input shaft)
I'm not sure about this last part---some E body bells may be bigger OD than your original A body, may be floor interferance.
(This was the case, example, between 69 and 70 RR. My 69 383 RR had a "real" 11" clutch, while my '70 used the horried 10.9 design. This used a 10 1/2" bolt pattern, modified cover, which would "drag" on the outer fringe of the disk as it wore. This was to allow a smaller bell in the car)
lifted150
Sep 29, 2012 05:27 PM
1966sportfury
Jul 6, 2010 04:27 PM
mitchs66
Feb 3, 2010 09:50 AM
theomahamoparguy
Dec 5, 2009 03:12 PM
sgoffena
Nov 9, 2007 07:55 PM
