any1 have nos on a 318?
Old Apr 7, 2009 | 11:08 AM
craveman's Avatar
Senior Member
i was just wondering if anyone in here has nitrous oxide on a 318 engine. just wondering what setup you used, the hp output and cost and any other modifications needed. ive got a 20lb bottle mounted in my car but its just for looks and was thinking about hooking it up just in case. also what is a safe maximum hp you could do on it?
Old Apr 7, 2009 | 01:58 PM
Zach8200's Avatar
ahh yes the Nitro got to love it personally i have only put it in gm 3800 with a super charger I even got it set up by a professional theres somthing about street engine that nitro dont like if you plan on having it on the street i wouldnt go any more than 100 but thats allot for the street i only shot 50 max and that tore the car inside and out i guess if you want to do it id do allot investigating on how to set it up i have blown 2 3800's im not going to say what to put in the mopar because i have had nothing but bad luck I hope you have good luck because let me tell you in will come in handy
Old Apr 7, 2009 | 06:20 PM
craveman's Avatar
Senior Member
well im in the process of finding an 8.25 or 8.75 i have 3.55 for the 8.25 but cant find a decent rear end anywhere. for tires i have 255/60/15 radials in the back. better than the 205's that were on it
Old Apr 7, 2009 | 06:21 PM
craveman's Avatar
Senior Member
you normally hit it in top gear right?
Old Apr 7, 2009 | 08:58 PM
craveman's Avatar
Senior Member
how long does a burst of nos last and how many shots do you get in a 10 lb bottle on a 100 hp kit. what about using it off the line for launches? do you just leave the line at about 2500 rpm then?
Old Apr 8, 2009 | 04:48 AM
craveman's Avatar
Senior Member
ahh ok then.
Old Apr 15, 2009 | 05:00 PM
deadkelly's Avatar
yeah sounds fun
dose the engine last ?
I'm scared of it ... i think I'd get hooked haha .
a 125 shot in a 383 is fine ya reckon ?
Old Apr 16, 2009 | 02:49 PM
deadkelly's Avatar
Originally Posted by hypermite
125 on a 383 should be no problem, as long as the engine is in good shape, (no blowby, or oil pressure issues) and the fuel system is up to it.
yeah my engine is still fresh sorta it's only had about 600 miles since rebuild . stock rod bolts are sweet ?. it's coping another rebuild asap as soon as have the . i would like it to run 11's off the bottle & maybe 150 -200 gas to break in to the 10's . it should have 500-550 hp with out the bottle . nitrous sounds fun . it may go low 10's with a 200 shot @ 127mph . ( 3.9 gears )
Menno
Oct 30, 2011 09:19 PM
koondawg_74 roadrunner
Nov 25, 2009 12:05 PM
Oct 25, 2009 10:58 AM
mopar nate
Mar 18, 2009 05:49 AM
440roadrunner
Jan 25, 2008 11:48 PM
