Bad pump?
Bad pump?
My front windshield washer has recently stopped working. Bad pump, blown fuse...? When I push in on the turn signal switch to activate the washer (1997 Grand Caravan), I don't even hear the little motor, and nothing happens.
find pump near washer tank. Test for 12volts at the clip. Just pull it, one wire is neg the other will have 12v when switch is pressed. If no volts present you have an electrical issue. If voltage present you have a pump issue.
