Bad pump?
Old May 2, 2012 | 09:02 AM
Alexandra's Avatar
Bad pump?
My front windshield washer has recently stopped working. Bad pump, blown fuse...? When I push in on the turn signal switch to activate the washer (1997 Grand Caravan), I don't even hear the little motor, and nothing happens.
Old May 2, 2012 | 12:42 PM
PK1's Avatar
PK1
find pump near washer tank. Test for 12volts at the clip. Just pull it, one wire is neg the other will have 12v when switch is pressed. If no volts present you have an electrical issue. If voltage present you have a pump issue.
sgp7679
Oct 31, 2009 07:34 AM
cide
Sep 8, 2008 08:47 AM
Joel@lavinconstruction.co
Apr 27, 2008 03:58 PM
1cerberus4u
Apr 18, 2008 06:55 PM
62sportsweep
Apr 7, 2008 03:38 PM
