Ball Joints 76 Dodge Dart
Old 06-16-2011 | 08:23 PM
samuelcosmo76's Avatar
So my haynes manual says the lower ball joints get bolted in as part of the steering knuckle. simple enough.
Are the uppers threaded in or pushed in? If they're threaded, I might as well take them to a machine shop instead of buying a socket. Anyone know?
Old 06-16-2011 | 09:44 PM
They are threaded !
Old 06-17-2011 | 07:18 AM
If mopar didn't change anything, they should be threaded. Unless you have the socket, taking it somewhere would probably be the best bet.
Old 06-17-2011 | 07:29 AM
thanks guys.....luckily the machine shop is around the corner from my house!
Old 06-18-2011 | 08:43 AM
Guys sorry for the retarded questions....What is the proper procedure for replacing the lower ball joint? Do I have to relieve the tension on the torsion bar first?
Old 06-18-2011 | 11:59 AM
No dumb questions. Yes, support at crossmember first and let suspension sag then back off bolt. Count the number of turns to get it back to same height when done. Much easier to turn bolt with weight off.
Old 06-20-2011 | 03:20 PM
Thanks!
Old 06-28-2011 | 01:47 PM
DONE. Man, that was a pain in the ***! Took an hour of hammering for EACH ball joint to pop them out of the knuckle. God damn. Alignment tomorrow!
EdR
11-16-2011 06:13 PM
Dodge Phoenix
11-03-2011 10:02 PM
xjonathanx
06-21-2011 09:23 PM
phil111260
02-03-2011 05:17 PM
gihuff
06-26-2009 04:15 PM
Quick Reply: Ball Joints 76 Dodge Dart
