big block ideas anyone?
Old Dec 3, 2009 | 03:48 PM
jspataro's Avatar
hey guys and girls.. i got a stock 440 out of a 71 imperial.. gonna build it for my dart. Probably see some track time and still street it.. have 391 gears in it now. was gonna leave bottom stock and put purple shaft hemi grind cam with a set of edlebrock aluminum heads and not sure on intake and carb yet.. what kinda set up should i go with? Thanks again
Old Dec 4, 2009 | 01:10 PM
well, if you are going to use aluminum heads, watch your compression
i've heard good things from stealth heads
how long have you had the car?
Old Dec 4, 2009 | 03:33 PM
jspataro's Avatar
I bought it about a week ago.. no motor or trans.. it had a big block in it... and since i have a couple thats what i'd like to put back in it. as far as compression was probably gonna leave stock bottom end in it.. i'm not sure what they would be pushin in a 71 steele crank motor..
Old Dec 5, 2009 | 07:59 AM
definetly find that out first
you'll pretty much always be using 93 octane right?
Old Dec 5, 2009 | 04:04 PM
jspataro's Avatar
thanks for the advice 67 GTX i'll check into it...
Old Dec 5, 2009 | 06:35 PM
John Van's Avatar
The '71 440 only had 8.5:1 the pistons are way down in the hole.If you are going to freshen up the motor with new rings/bearings anyway I would take the block to a machine shop and have it decked to maybe .005 to .010 in the hole,or go the better route with a stroker assembly,the piston,rod would be a lot lighter for faster acceleration and more power. just my .02
Old Dec 6, 2009 | 11:01 AM
the 71 440 was still high compression
it wasn't until 72 that they became low compression
Old Dec 7, 2009 | 04:20 PM
John Van's Avatar
He said it came out of a '71 imperial,normally it would have been the 335hp version which was8.5:1. you are right though, the 440 high performance 370hp was 9.5:1 and the 440six pack 390hp was 10.5:1 but I don't think he has either one,but you never know!
Old Dec 7, 2009 | 04:21 PM
ah
you are right
i was thinking of the 350hp one
Old Dec 8, 2009 | 01:09 PM
jspataro's Avatar
well i've been lookin around and checkin things out.. I'm leanin towards the 500 stroker kit from 440 source then usin thier stealth heads.. just gotta sell some derby stuff to get the funds...haha thanks for the info everyone! I really like this site!!
Seanzie1405
20
Aug 7, 2013 12:31 PM
pipdog69
Mar 13, 2012 11:01 PM
68satellite
May 23, 2009 05:33 AM
Brent1960
May 17, 2009 04:25 PM
mahd
Apr 2, 2009 09:05 AM
