A body Pitman arm size issues
Old 05-01-2010 | 12:38 PM
SXPKDuster's Avatar
Junior Member
Thumbs down A body Pitman arm size issues
I have recently replaced my power steering with a manual unit for clearance and to clean up the engine bay, the power steering that was in it was the original 73 stuff and the pitman arm shaft is 1 1/12 inch, the manual box I installed had to have come out of an older car since it appears to have the 72 and older 1 inch pitman arm shaft. I also think the box came out of a truck due to the pitman arm shape. My question is this, are the a-body pitman arms of 1972 and older the same as the 73 and newer except for the pitman arm shaft diameter, with my luck Im sure they are not. Any answers will be greatly appreciated. It doesnt steer well without the pitman arm.
Old 10-07-2014 | 01:05 PM
Nelson7797's Avatar
Pitman Arm Info
1972 and earlier steering boxes(power and manual) had the small sector shaft and the pitman arm drops down and meets the center link from the bottom.
1973 and later steering boxes had the larger sector shaft and the pitman arm meets the center link from the top.
The hole for the pitman arm bolt in the center link is tapered relative to the year.
In order to use an earlier box in a later model, the center link, idler arm and pitman arm must be changed. So the easiest solution is to get the right box.
I have a later box for my 72 Dart and I am facing this dilemma now. It is frustrating.
Old 10-07-2014 | 02:29 PM
save all of the old stuff.....Have you tried to flip the arm over ?
Old 10-08-2014 | 10:15 PM
Nelson7797's Avatar
I found some new information. Not sure how accurate this is, but it's more information nonetheless.
http://www.bigblockdart.com/techpages/steeringbox.shtml
castillo70
12-05-2012 08:45 PM
shovel55
11-15-2011 05:42 AM
Polara_68
04-19-2009 04:37 PM
Polara_68
04-15-2009 12:53 PM
upnorth52
10-23-2008 10:07 PM
