cam wont fit!
Old Apr 23, 2010 | 05:01 PM
getsum's Avatar
cam wont fit!
i tried putting my new cam in my 440 yesterday but the dam thing wont fit. i put new bearings in it and the old cam will slide in but the new one wont. i pulled the bearings out one by one to see what one was stopping it and it was the back one. i measured the bearing installed and the cam and there the same size. the old cam is only .001 smaller and i goes in. i know i need 1-2 thousands clearance.
so what should i do to get it to fit maybe hone where the bearing sits so it dosent smash the bearing so much or hone some material out of the bearing?
Old Apr 23, 2010 | 05:09 PM
scotts74birds's Avatar
Read something about this. Check here. Bottom of page on right. "WHy my cam wont turn". Good site for other reading too.
http://www.musclemotorsracing.com/muscle-mike-blog
Old Apr 23, 2010 | 05:18 PM
getsum's Avatar
That explained my problem and gave me a solution (back to the machine shop).
how do you find all this info i looked for a while and came up with nothing.
thank you
Old Apr 23, 2010 | 05:49 PM
Polaradude's Avatar
It's quite simple..THIS PLACE ROCKS.
Old Apr 23, 2010 | 06:07 PM
Knowledge is POWER! Free your mind and your *** will follow! Nah..just dumb luck. Even a blind finds a nut once in a while!
Old Apr 25, 2010 | 12:21 PM
jusglazin's Avatar
Cam won't fit?
I just had the same problem with my 440. I bought a comp thumper cam, machine shop installed new bearings but when I tried to slid it in it woould only go half way without force. I thought the bearings were installed wrong so I tried the old cam an it slid right in with no problem. I took both cams to the machine shop to have them checked and they verified that the center journal on the comp cam was 20 thousandths to big. I had them polish it down. Comp is getting slack on their QA.. Or should I say the Chinese!**^^%##.
maca
Jul 12, 2014 08:45 PM
Moss
Apr 27, 2014 09:14 PM
Zorro
Aug 26, 2011 09:06 AM
bugy
Feb 1, 2011 08:51 AM
dodgeaspenrookie
Jul 18, 2008 07:28 PM
