compression
Old Jan 3, 2009 | 02:15 PM
do you mean on a compression gauge?
stock compression was around 10 to 1
Old Jan 3, 2009 | 02:58 PM
i think, think, if it is stock compression, it should be somewhere around 150
but im not sure
but, the readings that you get should be within 10 of each other
Old Jan 3, 2009 | 03:20 PM
Those numbers seem a little low. How many times did you turn the engine over? you should turn it over til the gauge stops moving, which should be in 5 full rotations.
Old Jan 3, 2009 | 03:58 PM
deadkelly's Avatar
my 383 .040 over is 130 psi , i hope thats around 8 too 1 or better . iam not sure , but iam sure you only take 1 plug out at a time .
Old Jan 4, 2009 | 05:59 AM
BuckNeccid's Avatar
Good rule of thumb... sea level mean atmospheric pressure is 15 psi. 10-1 compression should give you 150 lbs, or thereabout, even if you're not at sea level. Lower ratios, lower levels, for instance, 8-1, 8 times 15 = 120 lbs. When you check your compression, you really shouldn't have much more than 10% difference between the highest compression and the lowest. More than that, you should be seeing what problem you have with your motor.
Old Jan 4, 2009 | 07:34 AM
The plugs I run are, i think J13Y?
Old Jan 4, 2009 | 08:39 AM
Originally Posted by raycer5
had wife turn engine over till gauge quit rising then when she stopped the gauge started going down. is it bad gauge or bad engine.or bad checker.i had all spark plugs out is that what your supposed to do .
How far did the guage go down? The guage should stay the same when you are done turning the motor over.
Old Jan 19, 2009 | 03:58 AM
deadkelly's Avatar
also if you have a large duration cam with over lap you won't get a true reading at turning over speed . was told that just the other day so i may have more comp than i thought .
Old Jan 19, 2009 | 09:06 AM
how did it turn out raycer5?
Old Jan 21, 2009 | 01:25 PM
no problem
pray for warm weather
Old Feb 3, 2009 | 09:23 PM
deadkelly's Avatar
you can have our warm weather
Originally Posted by 67 GTX
no problem
take it away no more to pay , give me cold winter racing air any day , where not as cold as you guys though
Old Feb 4, 2009 | 05:09 PM
whats a usual temp. for winter down there?
jjg73
Jul 20, 2011 12:37 PM
69POLARA383
Jul 16, 2011 07:36 PM
Barfly
Jul 9, 2011 10:01 PM
Slice
May 21, 2011 08:10 PM
deadkelly
Jun 3, 2009 10:15 PM
