constant voltage?
Old Nov 30, 2009 | 10:33 PM
cyclone2321's Avatar
constant voltage?
i hate how my headlights and interior lights will dim or brighten depending on my acc. pedal.
is there anyway i can get my car to stay at constant voltage?
Old Nov 30, 2009 | 11:13 PM
johnthegoalie's Avatar
thinkin with me dipstick
welcome to mopar ownership
Old Dec 1, 2009 | 03:19 AM
Polaradude's Avatar
beautiful man
Old Dec 30, 2009 | 04:36 PM
recondotexas's Avatar
hehe. I laughed on that reply for a good while. In the army our older model HMWWV's did the same thing until it warmed up enough. The mechanics said it was just "how it is".
Old Dec 30, 2009 | 11:58 PM
theomahamoparguy's Avatar
you need to read the "tech" articles at this site. www.madelectrical.com
It will be very enlightening.{pun intended}. (read the one about the dodge pickups particularly),
Last edited by theomahamoparguy; Dec 31, 2009 at 12:00 AM. Reason: incorret site name changed
Old Jan 22, 2010 | 09:11 AM
Mopar_71's Avatar
Cool article about by-passing the AMP gauge.
I may try it when I get my car back from the body shop.
Old Jan 22, 2010 | 07:38 PM
yes, every tech article on that site is extremely good. Should be a must read 4 everyone. (not just moparites)
Old Jan 22, 2010 | 08:42 PM
scotts74birds's Avatar
I'm a big fan of that! There is no need to run current through an ammeter to get a reading. I think that I read an instrument company can change it to a voltmeter and silkscreen the gauge to say "volts", matching the other gauges.
Old Jan 24, 2010 | 08:02 PM
GEORGE68HEMIRR's Avatar
Member
you could also up-grade to relays for the headlites....did that to my car and man what a difference.....very simple deal to....your headlites will have 14 volts at all times and all your switch does is turn them on and off....you dont have all the current running to the switch and back to the headlites....read about it... www.madelectrical.com
Old Jan 25, 2010 | 06:01 PM
i kinda understood what they were talking about.
im not electronically inclined so i had a big question mark above my head.
would i be able to make this kit myself?
Old Jan 26, 2010 | 06:37 AM
Member
okay...you read this....http://www.madelectrical.com/electri....shtml....then read thishttp://www.moparts.org/Tech/Archive/elec/10.html....i went by this diagram with these relays and followed this.....takes about a 1/2 hours..bought relays at NAPPA....bosch relays...i put the relays next to the radiator ...driverside and tapped into the headlite harness....ran wires from altenator but you can also come off the battery.....very simple and when you are done you will be amazed with how brite your headlites will be.....do it......good luck
COPY AND PASTE MOPARTS TECH THINGY TO READ
Old Jan 26, 2010 | 08:56 AM
Red Devil's Avatar
Little Demon
very intersting
Old Jan 26, 2010 | 03:45 PM
kids mechanic's Avatar
Junior Member
Did you replace your voltage regulater? or check the out put of your alternater? they'll do all what you said. Also you could just have a bad ground (god forbid with mopars). are you running a BOOM BOX?
Old Jan 26, 2010 | 04:50 PM
Member
Originally Posted by Red Devil
very intersting
ITS SO INTERESTING AND WORKS GREAT...ALSO HAVE A POWERMASTER MINI 1 WIRE ALTERNATOR WITH A BUILT IN VOLTAGE REGULATOR....MY ELECTRIC WATER PUMP ,TWIN SPAL ELECTRIC COOLING FANS ALSO HAVE RELAYS SO THEY RUN AT 14 VOLTS TOO.....ALL CARS TODAY HAVE RELAYS RUNNING EVERYTHING
Old Jan 26, 2010 | 08:08 PM
Red Devil's Avatar
Little Demon
sounds like a good setup...you are 100% correct, relays galore on newer cars
Old Feb 25, 2010 | 06:12 AM
cuda66273's Avatar
Junior Member
Tuff Stuff 100 Amp, one wire, internally regulated Alternator will solve all the issues and still be a Mopar.
Google: Mopar Mini Starters and Alternators
dodgeaspenrookie
Jul 23, 2012 12:15 PM
scott2683
Apr 18, 2010 07:57 PM
sgp7679
Nov 18, 2009 04:07 AM
440Challenger
Aug 13, 2008 03:04 AM
71 GTX
Feb 20, 2008 08:07 AM
