Dana 60 Powerlock side gear upgrade
Does anyone know if you can swap out 23 spline side gears on a 70's Dana 60 Powerlock with 30 or 35 spline side gears? I've heard that the carrier case halves might not have a large enough diameter hole to accept the larger 35 spline (or even 30 spline) axles and side gears. Would the 4 pinion mate gears and clutch rings have to be replaced also? Any help would be appreciated.
Just found out that the clutch rings are the same so I can use the old ones. Actually Dana 60 and Dana 70 Powerloks both use the same spider gears. And I think all you can interchange parts on older Dana 60 Powerloks with later models.
