Dart sport 360 Question
Old Jun 19, 2010 | 05:13 PM
Johnrily's Avatar
Junior Member
Hello all, i bought a dart sport 360 last summer and i want to just do a tune to make sure it continues to run properly, i have changed the oil,air filter replaced plugs. It a few months ago it did develop a dieseling issue but i will have to just let professional handle that.
My Question is for the life of me i cant find the fill plug for the manual transmission i own the Hanes book but it does not give a good picture of it. It is a 4 speed Hurst equipped transmission if that helps. im pretty sure i found the drain plug that was simple but the fill plug is another story. Any other tips would be help greatly as far as keeping my new baby running well.
Thank you for your help!
Old Jun 19, 2010 | 06:55 PM
1966sportfury's Avatar
A.K.A Bob Dodge
drain plug is on the left side of the housing there is a place that looks like you can stick a 1/2 ratchet head or extension in it. That's the refill plug. You take the ratchect put it in the square hole and pull the plug. You may need a short extension to clear other parts. dieseling poor grade fuel or timming just a bit out,
Old Jun 20, 2010 | 04:28 PM
Mopar_71's Avatar
The lubrication fill plug is on the passenger side on the main housing. A square looking plug.
I used a turkey baster to put the gear oil in the tranny and used an old cookie sheet to catch anything that might have dripped while doing this.
Good luck with your diesiling problem.
Old Jun 21, 2010 | 08:31 PM
Johnrily's Avatar
Junior Member
THANKS A TON! you guys rock!!
BTYM
Mar 8, 2014 08:22 PM
73Badsport
Jun 26, 2009 10:53 AM
O12kona
Jun 25, 2009 04:54 PM
makemineduster
Oct 14, 2008 04:27 PM
dartkid2733
Sep 14, 2008 03:17 PM
