Day at the Track 11/15
Old 11-16-2009 | 03:52 PM
Went to the track yesterday with the GTX, and had some trouble with it.
Left the line at 1500 rpm.
The car still isn't where it needs to be. We actually were slower than the last time we went, when we had the distributor problems.
Here is the best timeslip:
R/T: .056 (Had a better time in an earlier run)
60': 2.560 (Had a better time in an earlier run)
330: 7.246
1/8: 10.862
miles per hour: 67.56
1000: 14.024
/4: 16.607
miles per hour: 88.27
Car seems to be starving for fuel. I already have an idea to fix that. Can anyone explain why we were slower this time?
What should the timing be set to on the car when we race? it was changed from 12 to 7.
More pics and a video will be posted later.
Old 11-16-2009 | 05:23 PM
Crazy4Carz.Com's Avatar
Your biggest problem from your times posted is your 60'. 2.56 is tough to make up for at the other end. Are you spinning? is it bogging? how hard is your launch? We need to get you out of the hole better. Just a half second in the first 60' makes a HUGE difference at the big end.
Auto trans right? are you powerbreaking at the tree? Do you know what RPM it is leaving at?
I'm fat and that weight slows me down, I met you and I know you have no weight issues. Car looks great too!
Old 11-16-2009 | 05:45 PM
Well, the tires did not seem to spin.
The car seemed to bog down.
Left at around 1500 rpm.
It is a 4-speed.
Haha, I still weigh 165, but my Dad drove it yesterday.
Thanks, the car photographs well
Old 11-19-2009 | 02:36 PM
MrOldart2U's Avatar
Try a launch @ 2000 rpm's...if it still seems 'lazy' try 2500... you want the point right before the smoke show will start...
Old 11-19-2009 | 03:07 PM
i will try and fix the fuel problem this weekend.
will a stock fuel pump be enough for this car?
Old 11-19-2009 | 05:42 PM
Your stock fuel pump should be fine.
Old 11-20-2009 | 06:43 PM
what kind of time should I be looking for at my 60'?
Old 11-23-2009 | 03:05 PM
I got rid of the kinked fuel line
i also re-adjusted my idle screws
and I checked my vacuum at idle
I have 22 HG
Old 11-23-2009 | 09:22 PM
John Van's Avatar
With that much vacuum I guest the motor is all stock right? What gear is in the rear? What rpm are you shifting at? And last, what do you have for rear tires?
Old 11-24-2009 | 04:19 PM
the car has an edelbrock cam
bored 30 over
headers
electronic ignition
bigger exhaust valves
3.54 rear end
shifting at 5500, although it didnt make it there on the 15th
rear tires are 235 70R/15
tried the car today with the new fuel line, and it didnt seem to bog at all
Old 11-24-2009 | 08:14 PM
John Van's Avatar
That kinked fuel line must have been your problem.Your setup seems fine,but a bigger tire would help (mt drag radials are great!) For the timing look at 35-38 total advance, all in by 3000 rpm. Great looking car by the way!
Old 11-25-2009 | 04:18 PM
thanks
the car has a new mopar performance distributor on it
Sgt. Veteran
06-01-2010 08:45 AM
67 GTX
09-14-2009 06:54 PM
MrMopowered
05-13-2009 03:32 PM
Polaradude
03-03-2009 05:23 PM
StanH
12-15-2008 09:35 PM
