double single or none stud starter fastner
Guest
Posts: n/a
When you guys rebuild a belhousing do you double stud, single stud top or bottom, or just nut and bolt for the starter attachment?
I have found that 675-033 Dorman studs work well both top and bottom or you can weld 675-010 on the NC side at .500 to bottom out and work fine. Also Fastenal 22870 bolts, work great.
I use Nippon Denso mini starters for everything I put together.
98 SNAKE EATER
Mar 23, 2013 07:51 AM
