Fuel Tank Ground
Old Aug 7, 2009 | 06:30 PM
3x2v's Avatar
Junior Member
Fuel Tank Ground
Fuel gauge worked fine. Changed tank, sending unit, fuel lines, ground strap (sending unit to fuel line). Now I have a bad ground, cause the gauge is pinned beyond full. Isn't the sending unit also grounded from the tank to the straps to the frame
Old Aug 8, 2009 | 04:14 AM
Crazy4Carz.Com's Avatar
Nope. The tank is insulated via the pads between the straps and the tank. the sending unit is insulated because of the gasket. There is a little metal "strap" that clips onto the fuel line before and after the rubber hose that connects the pick to and the main fuel line. This strap MUST be there.
Old Aug 8, 2009 | 03:20 PM
3x2v's Avatar
Junior Member
I haven't tried the old sender yet cause I don't want to drop the tank if I don't have to. I do have the strap on the sending unit to main fuel line. I think if the gauge is all the way past full that I have a grounding problem. Maybe the insulation on the straps is failing or the gasket on the sending unit isn't seated properly. The sending unit is suppose to work between 0-100 ohms all of my testers say 1K next to ohms so that means 1000 is the minimum?
Old Aug 8, 2009 | 03:31 PM
scotts74birds's Avatar
See if your testers say or have "auto-ranging", or a "range" button. I hope thats what you were asking re; the tester. Here's two sources about fuel gauges that I keep in my bookmarks, I hope they help you. http://www.moparfins.com/Repairs/Fue...uge_Repair.htm http://auto.howstuffworks.com/fuel-gauge1.htm
Old Aug 9, 2009 | 07:28 PM
3x2v's Avatar
Junior Member
Its a 70 GTX, and thanks for all the input. I have a few things to check on now.
THE GOOSE
Jan 19, 2014 01:31 PM
mrzods13
Aug 19, 2013 05:48 PM
mytracy
Dec 24, 2010 11:19 PM
Cal Lawton
Oct 6, 2009 03:16 PM
-69 B/RB
Jan 7, 2009 07:08 PM
