1969 Roadrunner wiring ground issues
Old Oct 5, 2009 | 04:00 PM
scotts74birds's Avatar
Cal, are you sure you found them all? but you are right on the grounds issue. Its hard to tell you from here how to do it. From the schematics I have, the right front lighting system appears to ground at the front turn signal lamp. This is however a schematic, not a blueprint. Locations may vary. Heres the pic, http://www.mymopar.com/downloads/196...oadRunnerB.JPG Keep us posted.
Old Oct 6, 2009 | 03:16 PM
Once you've located the ground wire, you could try jumping it a different points along it to find the bad section with a good ground. My experience is that most wires dont go bad in the middle, usually its a termination of some sort. But as an industrial electrician, I also dont run into mice under the hood often either!
THE GOOSE
Jan 19, 2014 01:31 PM
lgad
May 12, 2011 04:36 AM
mytracy
Dec 24, 2010 11:19 PM
3x2v
Aug 9, 2009 07:28 PM
-69 B/RB
Jan 7, 2009 07:08 PM
