have water in oil cant figure it out help please
Old Jun 29, 2009 | 08:39 PM
water? do you mean coolant? If so then your block could be cracked or warped. What motor is this happening on? Waterpump could be leaking inwards.
Old Jun 29, 2009 | 09:39 PM
have you done a compression test and leakdown test on all the cylinders?
Old Jun 29, 2009 | 11:28 PM
Rings could be shot or not lined up properly. That wouldn't explain the coolant in the oil tho. I would send the heads out to be checked. if you are pulling the block out as well, or already have it out, I'd send that out too.
Old Jun 30, 2009 | 08:41 AM
your black could be cracked
it could just be another bad head gasket
74Runneer
Jan 11, 2015 01:20 PM
hellzombiex
Apr 18, 2014 09:13 AM
kids mechanic
Jan 4, 2010 04:36 PM
dzltd02
Oct 28, 2008 08:25 AM
reallylongnickname
Sep 11, 2008 04:28 AM
