Headlight Switch
Old 02-11-2011 | 09:05 PM
Satellite72's Avatar
Headlight Switch
Quick Question about removing a headlight switch....I suspect my headlight switch has gone out (no dash lights or tail lights, yet fuse is fine), so I was hoping to remove it sometime this weekend. Can it be removed and replaced with the instrument cluster in place or do you have to take off the istrument cluster too? It's a ralley instrument cluster by the way. Thanks
Old 02-12-2011 | 02:02 AM
Greaser's Avatar
i have been told you can. i believe mine has gone out on me as well, i talked to a few guys and they said that it is more than likely a "cold" solder but i have not had the testicular fortitude to attempt to re-solder it.
Old 02-12-2011 | 08:57 AM
Thanks. I'll try to get under there and take it out hopefully today or tommorrow.
Old 02-13-2011 | 07:54 PM
I'm guessing that was the problem, considering the switch and part of the wiring harness connector had melted plastic on them.... Going to have to put some more female connectors on there another afternoon.
cuda101
10-01-2014 08:50 PM
Homer_J
09-15-2013 06:16 PM
Arbiter343GS
10-31-2011 09:44 AM
Satellite72
04-10-2011 12:11 AM
dorseyh
08-22-2009 11:27 PM
Quick Reply: Headlight Switch
