HELP Unexplained Stall D150
Old Jan 2, 2009 | 08:10 PM
welcome to the forum!
Sounds to me like the carb needs to be cleaned and or rebuilt.
Old Aug 21, 2009 | 07:56 AM
DodgeW200's Avatar
I agree, sounds like carb. I have a 75 W200 with a 360 that originally had a 2 bbl with the same problem. I had the carb rebuilt for $150 back in the late 90's. I have since moved on to a 4 bbl. You could try running several tanks with fuel stabilizer in it (sta-bil) and try cleaning as much of the throat of your carb with a carb cleaner as you can. Sometimes this may dislodge any gum deposits that are either occluding a jet or causing the needle and seat to not seal properly. I did this for a friends carb on a truck he couldn't keep running and he managed to avoid the carb rebuild. However, I recommend the rebuild as this doesn't always work.
Potterymaker1
Feb 10, 2012 07:02 PM
sgp7679
Aug 21, 2009 07:19 PM
Budsjlm
Aug 20, 2009 12:41 PM
thedusterridesagain
Jun 4, 2009 04:26 PM
cfryerson
Jan 5, 2009 06:39 PM
