Hood latch assembly
Old Jun 9, 2024 | 04:55 PM
MarD250's Avatar
Hood latch assembly
My 84 Dodge D250 318 gasser hood is stuck shut... I bought a new cable latch for it and my mechanic guy broke it already... so it's not releasing the hood! I'm hoping to reach out to somebody that actually knows the specific hood latch/lock/mechanism that I have on this particular year/model (1984 D250 318 motor) & what I can I do to manually release the hood? also could use a diagram/picture of where to release the spring action latch and what tools I could possibly use without drilling holes in my truck... I've done two days worth of searching on a few of the most popular search engines goo/tube and I keep getting beat around the bush with other vehicle models/ 2500/3500 series Dodge pickups... Yeah I'm bummed I just did a leveling kit on it and we got it off the jack stands...Go to open the hood the hook up the negative battery cable & the hood is stuck shut and I'm going WTF? Ask my buddy that's been doing the work on it, "why is the grill off" 🤔
He says he can't get the hood open, it's stuck shut...So, that's where I'm at I
You can see how the front end is sagging so I did some Three inch spacers I tried bigger springs but they were too stiff... No pics after we leveled her up but I did get about 3 in
can't start my truck and test drive it till I get this freaking hood open...
Old Jun 10, 2024 | 04:35 AM
Kuvasz101's Avatar
Of course, without seeing the latch it's difficult. The bolts holding the latch in place, can you get in there and remove them?
Old Jun 10, 2024 | 08:47 AM
Shoot us some photos of what you can of the latch......
If i recall... On the front side of the latch closet to the grill... you can see a little hole in one of the moving brackets... If it has that little bracket you can pull down on it and the hood should latch will release... That part also work in combination with the part that works with the cable end....
Hope you can unbolt it like Kuvasz said....
Old Jun 13, 2024 | 10:55 AM
MarD250's Avatar
Good News
My buddy got the hood open while I was sleeping... Thanks for taking time out of your day to reply to my problem!
Last edited by MarD250; Jun 13, 2024 at 10:57 AM. Reason: Wanted to thank the guys that replied
Old Jun 13, 2024 | 10:56 AM
Awesome... I hope the info helped... Cheers
Old Jun 13, 2024 | 11:09 AM
MarD250's Avatar
Mechanical fuel pump
Hey racer hog, you got any insight on the mechanical fuel pump? I've added an electric fuel pump cuz I got tired of messing with the mechanical... Right now the electric is running through the mechanical and I want to bypass the mechanical pump... Do I have to remove the mechanical pump and put a blank on the whole or can I leave the mechanical on the vehicle and run a fuel line loop?
Old Jun 13, 2024 | 12:33 PM
Leave the pump and just run a bypass tube with a couple hose clamps,,,, Should be good to go after that...
Dont forget to check the fuel pressure to make sure your not putting to much pressure in the needle and seat....
Old Jun 13, 2024 | 02:28 PM
MarD250's Avatar
Thanks👍.... I'll try that... sounds like the easiest way to go for right now
usrmed
Apr 14, 2018 05:50 PM
dgbcharger
Apr 20, 2015 06:01 PM
Jake Compton
May 14, 2014 06:32 PM
lstaats
Jul 22, 2011 10:39 AM
dodgenut7
May 30, 2010 07:45 AM
