HOW DO I TELL ROCKER ARM RATIO
Old Sep 24, 2011 | 11:24 AM
SPICOLIE203's Avatar
Hi all,
I have a318 with stock heads and the stock stamp steel rocker arms. I also have a set of adjustable stock rocker arms from a 273 . In both my manuals I cant find anything that says what the rocker arm ratio is.
1. Can I swap the stamped for the adjustable rocker arms out (Knowing I will need to measure and have pushrods made)
2. Does anyone know if the 273 stock rockers are the same ratio as later model stamped steel .
I know that the rocker arms and shaft fit just dont want to buy cutstom pushrods to have them not work.
Old Sep 24, 2011 | 06:58 PM
They are both 1.5, the deciding factor is the adjuster on the rocker. Cups and ***** have to correspond, and you can get differnent adjusters if you want. ***** on the rocker with cups on the pushrod lessen possibility of cracking. I would suggest getting new rods, most suppliers will lend an adjustable to measure accurately.
Old Sep 25, 2011 | 08:02 PM
Awesome thanks i have the measuring tool so i will measure up and go from there thanks everyone.
440 aspen
Nov 19, 2013 11:31 AM
madman23420
Aug 8, 2011 11:07 AM
69POLARA383
Sep 24, 2010 11:29 PM
fivepoint
Jan 9, 2010 09:28 PM
Commando
Jan 7, 2009 07:20 AM
