i think my engines about to die.
oil: check new air filter: check. i turn my car on and it doesnt stay on. it sputters, i need to really give it gas to keep it runnin. a lot of smoke. light smoke not dark. eventually after it warms up its fine though
could it be my engine? carb? it was running perfectly days ago. no problems at all
what do you mean between the seat and the steering wheel? yes coolant is fine. How do i check compression/? i have a leaky power steering line. so i added a little bit they day before it started happening.
What is the only thing that connects the seat and the steeing wheel together?
You'll need a compression gauge (can get one at any decent parts/automotive tool store). I pull the wire off the coil as you do not want spark and or fuel while doing this. Pull out one plug and thread in teh hose for the gauge. crank the motor over about 4-5 times. record what the gauge is reading. You want only a 10% difference between all the cylinders and about 90-120 PSI of compression. (a manual is great help for this).
i filled up my car with gas about two weeks ago.it finally got low so decided to fill it up again today, when i notice i didnt have the gas cap on. I must have left it at the gas station two weeks ago. could that be it? (compression)// i bought a new cap, changed the gas to a higher premiumand took it for a ride. the engine didnt even make a peep. normally i hear a bunch of pings when i step on it.
You don't live in a place where the kids are known for putting sugar in the tank? Could also be dirty gas, water in the fuel?
Guest
Posts: n/a
maybe but what you need to do is figure out your compression ratio and then use the octane that can handle it, i think its up to 9.5:1 is 87 then 11:1 is 91 and 12.5 is the highest you can run pump gas, im not positive on these numbers though but its close
I've found that the correct timing at wot is a balancing act between the dizzy and the proper jetting of the carb. This is NOT the PROPER way, but how I always did it was to mash the gas and advance the timing 2 deg at a time till it pinged. Then back off 2-3 degs. Pretty shadetree but I didnt care about the specs, I just set it to what the motor liked. I'm sure I'll get called out on this, but this is my personal experience, this is not meant to be advice.
I know this is an old post BUT.... you're supposed to pull all the plugs out before doing a compression test
Tom T2
Aug 23, 2015 07:21 PM
