i think my engines about to die.
Old Jul 29, 2009 | 10:04 AM
carlosg7915's Avatar
Member
oil: check new air filter: check. i turn my car on and it doesnt stay on. it sputters, i need to really give it gas to keep it runnin. a lot of smoke. light smoke not dark. eventually after it warms up its fine though could it be my engine? carb? it was running perfectly days ago. no problems at all
Old Jul 29, 2009 | 10:06 AM
could be a loose connection between the seat and the steering wheel.
have you checked your coolant? compression check? did you adjust anything at all?
Old Jul 29, 2009 | 10:09 AM
Polaradude's Avatar
x2 on what Tim wants you to check.
Old Jul 29, 2009 | 10:13 AM
Member
what do you mean between the seat and the steering wheel? yes coolant is fine. How do i check compression/? i have a leaky power steering line. so i added a little bit they day before it started happening.
Old Jul 29, 2009 | 10:14 AM
Member
could my leaky power steering line have got something wet?
Old Jul 29, 2009 | 11:24 AM
What is the only thing that connects the seat and the steeing wheel together?
You'll need a compression gauge (can get one at any decent parts/automotive tool store). I pull the wire off the coil as you do not want spark and or fuel while doing this. Pull out one plug and thread in teh hose for the gauge. crank the motor over about 4-5 times. record what the gauge is reading. You want only a 10% difference between all the cylinders and about 90-120 PSI of compression. (a manual is great help for this).
Old Jul 29, 2009 | 11:25 AM
maybe some wires but thats about it. I don't think it is the problem, although you should fix it.
Old Jul 29, 2009 | 02:04 PM
Member
i filled up my car with gas about two weeks ago.it finally got low so decided to fill it up again today, when i notice i didnt have the gas cap on. I must have left it at the gas station two weeks ago. could that be it? (compression)// i bought a new cap, changed the gas to a higher premiumand took it for a ride. the engine didnt even make a peep. normally i hear a bunch of pings when i step on it.
Old Jul 29, 2009 | 03:56 PM
ya
the higher octane stoped the pings
did the engine feel better?
Old Jul 29, 2009 | 04:12 PM
Member
wayyy better... expecially the top end.
Old Jul 29, 2009 | 04:13 PM
Member
but im still not sure if this was the problem. my mechanic skills are not that great, im just learning as i go.
Old Jul 29, 2009 | 04:26 PM
Told ya it was a loose connection. lol
Old Jul 30, 2009 | 06:22 AM
64fury's Avatar
You don't live in a place where the kids are known for putting sugar in the tank? Could also be dirty gas, water in the fuel?
Old Jul 30, 2009 | 08:49 AM
Member
not around here... it now the next day so im gunna go check to see if it fixed the problem. (cross my fingers)
Old Jul 30, 2009 | 07:36 PM
67Polara's Avatar
so what i got from this is if i put like 97 grade gas in my car it will stop all the sqeaking and pings i hear when i floor it ?
Old Jul 31, 2009 | 02:26 PM
scotts74birds's Avatar
I've found that the correct timing at wot is a balancing act between the dizzy and the proper jetting of the carb. This is NOT the PROPER way, but how I always did it was to mash the gas and advance the timing 2 deg at a time till it pinged. Then back off 2-3 degs. Pretty shadetree but I didnt care about the specs, I just set it to what the motor liked. I'm sure I'll get called out on this, but this is my personal experience, this is not meant to be advice.
Old Jul 31, 2009 | 03:58 PM
with carb. cars, the highest octane you can run, (With iron heads) without pinging is around 10.5-1 if you are lucky
Old Aug 30, 2010 | 08:19 PM
blue 68 gts's Avatar
I know this is an old post BUT.... you're supposed to pull all the plugs out before doing a compression test
Old Sep 1, 2010 | 10:27 AM
D100Guy's Avatar
i can see this is going to be a rough crowd....lol
Tom T2
Aug 23, 2015 07:21 PM
rcoopers
Aug 17, 2015 10:16 PM
Hutcla
Dec 1, 2013 04:00 PM
Coronet 500
Mar 26, 2013 07:44 PM
mopar777
Jun 5, 2011 10:42 PM
