Idle setting for a 69 roadrunner?
Old Aug 6, 2013 | 04:33 PM
383sweet69's Avatar
Can anyone tell me what the factory idle rpm setting should be for a 1969 roadrunner with a 383 motor I need to verify my idle setting before I can check the timing.
Old Aug 6, 2013 | 06:15 PM
inri's Avatar
I imagine there may be a slight difference in factory idling between a manual and an auto. For an auto I run 800 rpm at idle. BUT, I'm not stock.
Old Aug 7, 2013 | 11:35 AM
i'd try somewhere in between 600 and 700; for some reason, 660 comes to mind.
Old Aug 7, 2013 | 12:56 PM
moe7404's Avatar
most important is so it is not so high that it bangs in to gear, on an automatic trans.
Old Aug 7, 2013 | 01:23 PM
Archer's Avatar
383 -
Depends on a lot of stuff (like overall condition of the motor), but if basically stock, 700 - 800 in neutral and 600 - 700 in gear (auto). Drop from neutral to drive should be in the 100 - 150 rpm range.
Old Aug 7, 2013 | 03:57 PM
Curb Idle 750....
Old Aug 9, 2013 | 07:47 PM
383sweet69's Avatar
I had a chance to go out and fire up the RR to verify what the car was idling at. It idled about 1200 - 1300 rpm in neutral. This seems a little high compared to all the comments I received. To the best of my knowledge, the engine is a stock 383 with a Holley 4160 750CFM carb and a 4 speed manual.
Should I mess with the idle and drop it down around 700 rpm????
Old Aug 9, 2013 | 08:16 PM
inri's Avatar
Yes, in my opinion you should drop the idle down to 700-800. 1200-1300 is too high. Lowering the idle should take you no time at all.
Good luck.
Old Aug 10, 2013 | 06:21 AM
Archer's Avatar
383 -
If you lower the idle and the engine cuts off, there's a timing or carburetor problem that needs to be addressed.
Old Aug 10, 2013 | 08:46 AM
Open up the Idle air screws 2 turns.... Then try again...
JETBLU
May 1, 2015 04:05 PM
RROriginals
Jun 20, 2012 12:19 AM
aatkinsonalexdatkinson
Feb 1, 2012 08:13 AM
RXDawg
Feb 15, 2009 08:02 PM
Newf
Jun 22, 2007 09:44 PM
