IGN problem
Old Dec 9, 2023 | 06:03 AM
Grumpyolman's Avatar
IGN problem
I知 trying to delete the computer ign on a 1987 ply gran fury 5.2 . I知 installing the mopar ECU type ign . Question is will the engine / camshaft have to be upgraded to perform properly ? Due to the timing difference?
Old Dec 9, 2023 | 07:02 AM
I dont think so.
Should be able to install the kit and off you go.
Old Dec 10, 2023 | 06:20 AM
Kuvasz101's Avatar
The engine camshaft effects valve timing. Camshaft will determine how long and wide a valve opens and closes. Ignition timing determines when the engine sparks. By adjusting the timing with a timing light you move the distributor advanced or retarded signaling when the plug fires in relation to the piston. So your modification should have no effect. Good to go.
roadwolf
Sep 25, 2017 06:06 PM
Caigkersey
Jun 22, 2017 03:26 AM
68fury
Apr 21, 2015 02:14 PM
furysrule
Jan 18, 2014 12:58 PM
NOFRILLZ
Mar 27, 2011 04:59 PM
