Ignitor 11 help
Old Apr 28, 2009 | 05:20 PM
pjmopar's Avatar
Ignitor 11 help
Need help friends
I tried to install the ignitor 11 electronic ignition in my distributor with no luck.i removed the points and installed it.the problem i seem to have was removeing the ballast resistor,i also have a black box that has to wires running to it .One side say IGN,the other Field.My car is 1965 so im not sure what that box does.I contacted protronics tech and hes not sure about it either.any help would be great.Hope i explained this okay ,if not fell free to let me know
Thanks
Old Apr 28, 2009 | 06:24 PM
scotts74birds's Avatar
What engine, what car and what does the thing want you to hook up to?
Old Apr 28, 2009 | 06:55 PM
pjmopar's Avatar
It is my 65 plymouth and it has the y block 318.it recommends you eliminate the ballast resistor and run a hot wire to the coil ,but when i try and start it ,it will back fires through the carb,im thinking i must have a bad part.When i go back to the points it runs perfect.I just wanted the reliable electronic ignition .not so sure now
Thanks Scott
Old Apr 28, 2009 | 07:01 PM
64fury's Avatar
Never used a protronic's unit on a Mopar, but did have on on my MG and Triumph. With those it was possible to get the set up 180 degrees backwards so it would fire while on the intake stroke, which caused it to backfire thru the carb!
Old Apr 28, 2009 | 07:05 PM
Ok, from what I saw on the petronix site with the ignitor for the 12v ground system, the black wire should go to the neg of the coil. I dont see where it says to REMOVE the ballast resistor. If the resistor is kept, the ignitor red wire would go to the regulator side of the resistor. Looks like its dark blue on your car. http://www.mymopar.com/downloads/1965/65FuryB.JPG Hope this helps, it should be the schematic for your car.
Old Apr 28, 2009 | 07:10 PM
I'm happy to help. The wifes watching american idol now and its either help you or pound spikes through my eyes!
Old Apr 29, 2009 | 11:57 AM
theomahamoparguy's Avatar
Originally Posted by pjmopar
Need help friends
Thanks
The black box sounds like the voltage regulator.[ign. -field]. The old electromechanical type. [about 3 inches square?]
[most of] The aftermarket ignitions do not use the ballast resistor but that means you must use a compatible COIL to go with the aftermarket ignition. The factory old mopar coils were not rated for a constant 12+ volts. Use a MSD coil [non resistor type] . you need to know what coil is compatible with the system you have.
Old Apr 29, 2009 | 04:10 PM
pjmopar's Avatar
Thanks guys for your help .You know the old story when they run good leave them alone.I think mine is defective and im sending it back.Going back to the points for now .yes the black box is the alternator regulator
Paul
Old Apr 29, 2009 | 04:14 PM
pjmopar's Avatar
Hi 64 Fury .how would i get get them 180 degrees backwards
Thanks for your help
Old Apr 29, 2009 | 04:19 PM
Sorry bro, but keep that link I sent you and print those schematics. Very handy when you're on the side of the road. Hmmmm, how do I know that?
Old Apr 29, 2009 | 04:28 PM
pjmopar's Avatar
Thanks Scott ,I have already printed it out already
mrzods13
Aug 31, 2014 11:46 AM
mrzods13
38
Apr 26, 2014 07:01 PM
