key wont turn the engine over-66 dart
Old Jun 4, 2010 | 03:17 PM
66darter's Avatar
Junior Member
key worked one minute then wont, but the engine starts with hot wire
Old Jun 4, 2010 | 06:24 PM
Buffalojoe426's Avatar
Could it be a relay or solenoid gone bad?
Old Jun 4, 2010 | 07:01 PM
blue 68 gts's Avatar
Do you have ANY power at all?
Check all the connections at the bulk head and check the fuseable link
Old Jun 4, 2010 | 07:32 PM
67gtxclone's Avatar
Possibly a bad ignition switch???
Old Jun 4, 2010 | 07:40 PM
sweeperking's Avatar
Sounds like what I'm going thru now, I need a ignition switch. Check for power at the yellow wire at the starter relay with the key in the crank position.
Old Jun 5, 2010 | 02:53 AM
rdrunner1974's Avatar
starting
With the key turned to the start position, check for 12 volt at the start relay on the BLK-YEL-TR Wire. If you DO NOT have 12 volt your ign.switch is bad.
If HAVE 12 volt yor start relay is bad. You can use a jumper wire from the Red wire to the BROWN wire at the start relay which bypass' the start relay and if it cranks your solinoid is O.K. See the schematic.
http://www.mymopar.com/downloads/1966/66DartB.jpg
Old Jun 5, 2010 | 05:56 AM
There was another post here where some one didnt believe me when I said the neutral switch was the ground for the relay, wished I remembered I would like to show him your schematic.
Old Jun 5, 2010 | 01:56 PM
start relay
Yea King, I did'nt mention the neutral safety could be his problem. Maybe he'll post what he found wrong.
66FuryBoy
Jun 13, 2022 08:48 PM
74Runneer
Jul 31, 2013 10:01 AM
Dominic Torreto
Jul 29, 2012 10:07 AM
Hostile1
Jun 16, 2012 03:44 PM
duster74
Feb 11, 2009 07:43 PM
