mopar antifreez
Old Apr 18, 2009 | 04:04 PM
Polara_68's Avatar
MoparMania-no cure for it
I think if an antifreeze is sold as one of those 50/50 mixes,
then it has to say so clearly on the bottle..
Winter's pretty much over, you can run a 15% Antifreeze / 85% water mix
for better cooling (this applies to older cars that use regular green-colored antifreeze -
i have no idea about cars that dont use that type or use the orange stuff)
Just remember to swap over to a 50/50 mix for the winter.
older cars only need 15-20% Antifreeze for corrosion protection,
and plain old water is a far better coolant than antifreeze..
your car will run about 20 degrees cooler.
don't beleive me? Look it up lol
Old Apr 18, 2009 | 06:28 PM
craveman's Avatar
Senior Member
one of my friends has an 04 ford focus zx2 or something like that. on top of the radiator support it has a sticker that says mopar antifreeze on it and the mix ratios. his grandmother bought the car brand new and this sticker was on it from the factory
Old Apr 19, 2009 | 03:52 AM
so what you are saying is that ford secretly wants to be a mopar? NICE!
I have always bought the 100% anitfreeze and mixed it up myself 50/50. never have had a problem. Becareful though as some mopars came factory with a different color antifreeze, I think starting in 2002.
Old Apr 19, 2009 | 04:24 PM
i always used 50/50
Old Apr 19, 2009 | 07:01 PM
craveman's Avatar
Senior Member
i think the 50/50 also has rust preventative in it
Old Apr 19, 2009 | 07:02 PM
craveman's Avatar
Senior Member
could be wrong though i usually am if you go by my exes opinion
Old Apr 19, 2009 | 10:28 PM
theomahamoparguy's Avatar
Originally Posted by cnet15
Is mopar antifreez/ coolant 50% antifreez 50% water or 100% antifreez
It must say 50/50 if it has the water but I've read that the mopar antifreeze/coolant is extremely good quality. Probably better than the other big name brands. Like Polara 68 said, you can get away with running a small percentage of antifreeze in the summer.
Old Apr 20, 2009 | 01:29 AM
The water is the one that gets rid of most of the heat from the motor. THe anitfreeze is there to keep it from freezing (no brainer there) and to help lubicate the waterpump as the motor is spinning.
I agree that Mopar anitfreeze is really good stuff. I wouldn't use anything else minus Peak.
Old Apr 20, 2009 | 03:54 AM
rr69half6bbl's Avatar
I talked to a guy that runs a rad repairand recore shop, he told me the best thing hes found over the years is a 50/50 mix and to use distilled warter, this cuts the sorrosion out, since theres litle iron or calcium in it. Ive done this since talking to him in late 80`s, and every time I change the antifreeze in my mopes, after 2-3 yrs, its still green and has very little rust content in the wash out.
Old Apr 20, 2009 | 05:32 AM
Commando's Avatar
Just in case you guys didn't know there are only 3 companies that make antifreeze, all the other brands add stuff or change the mixture and put their name on it.
Old Apr 20, 2009 | 08:30 AM
craveman's Avatar
Senior Member
yeah you would be surprised how many fluids and parts are made by the same company. Advance auto parts oil is actually the same as some major manufacturer but at 2/3 the price. i forgot what he said it was though.
