My 440 needs help!
Old Jan 6, 2009 | 01:55 AM
BuckNeccid's Avatar
Sounds like a function of the timing and secondaries on the carb kicking in... just a few hundred rpm could make that difference, or a little faster slamming the pedal open.
Old Jan 6, 2009 | 02:14 AM
stock torque convertors have a stall seed of about 500 to 700 RPM, I'm pretty sure. I propbably would have gone with a stall convertor more around 1800 to 2000 RPM but like Buck said, it sounds more like a timing and carb issue to me. I would play around with the timing a little bit and go from there. If you can play with the secondaries, do that as well, but only after you are 100% sure the timing is DOBA.
Old Jan 6, 2009 | 01:42 PM
Polaradude's Avatar
This may be going in the wrong direction but is it possible you have a vacuum leak?
Old Jan 6, 2009 | 04:35 PM
what type of holley carb do you have and what do you have the timing set to?
Dave
May 7, 2009 05:39 PM
mopar nate
Apr 29, 2009 06:54 PM
valiant70
Oct 31, 2008 05:14 PM
65Satellite
Oct 21, 2008 05:26 AM
REDDOG
Dec 19, 2007 03:37 PM
