ohms value of ballast resistor
Old Oct 2, 2009 | 07:31 PM
nesparky's Avatar
What kind of ohm's value should I get when I check the ballast resistor? Its on a 78 cordoba with the lean burn system removed, and if I understand correctly I will have 4 wires going to the resistor; two on each post?
Old Oct 2, 2009 | 11:03 PM
grissomracing's Avatar
Member
depends on if you have a single or double ballast res. 2 posts or 4?
Old Oct 3, 2009 | 04:36 AM
nesparky's Avatar
I currently have a 2 post, is there a difference between the two?
Old Oct 5, 2009 | 08:59 AM
Member
Lightbulb
This link should help
http://www.mymopar.com/downloads/elecignconv.pdf
Old Oct 13, 2009 | 04:33 PM
MrOldart2U's Avatar
I hunted and hunted but I couldn't find the info, that I know I've seen, and thats the ohms resistance of a ballast resistor... My memory aint what it used to be but I'm thinkin it was like 0.08 or so....But don't bank on it either...
74Runneer
Jul 30, 2013 07:45 AM
440GTXguy
Apr 20, 2013 10:14 PM
jar84203
Oct 24, 2012 10:24 AM
toad490
Oct 11, 2009 01:03 AM
Mixmastermerrill
Aug 14, 2008 01:36 PM
