Oil Type High Mileage Car
My LHS is due for an oil change and I don't really know what oil type to go with. It has high mileage kendall oil in it right now since the last change. I wonder if I should go full synthetic, or what have you, any thoughts appreciated on the subject.
I have always had the understanding that if you switch to synthetic you'll need to stay with it cause the differences in conventional and synthetic will slowly cause gasket issues if you flip flop. I also thought the higher the milage the thicker the weight and conventional should be used, thicker to close up clearance and conventional to take away more deposits. Sythetic is good for lubrication do to the smaller molecules. That is my understanding on oil.
Guest
Posts: n/a
I've always heard not to switch to synthectics in high milage cars but I've done it in 3 different vechiles with no probs. If I was to guess the millage I'd say 180k, 150k, and 130k in a Corolla, 280z, and Dakota respectivly.
When not using synthetics like in one my 240z's that leaks so much it's not worth it I use Castrol GTX.
I've always used what was recommnded in my Ram, 10-30. But around 200k the oil pressure was starting to drop. Switched to 10-40 and its ok for now. I already replaced the oil pump, so it must be the mains.
No It's not having any problems with the oil at the moment.And to answer the what mileage question. It has 175xxx on it. And I heard the same about once you go synthetic you stay synthetic. I just don't know what would be best. It has the 3.5 H.O motor if that matters.
With that number of miles I'd recommend a high mileage oil. They are specially formulated to fight sludge and have added seal conditioners. If you are not having any problems with oil pressure I'd stick with the manufacturer recommended oil weight.
ShowYourAuto.com
Mar 18, 2011 11:24 AM
dzltd02
Oct 28, 2008 08:25 AM
