Play in steering wheel with new gearbox?
Old May 18, 2014 | 04:39 PM
Paladex's Avatar
So, I just replaced the tie-rod ends and steering gear on my '68 Fury. The Pitman arm had been replaced by the previous owner. The steering coupling is nice and tight. But, I STILL have play in the steering wheel. That is, when I turn the wheel, it moves a few degrees before engaging. I strongly suspect that I changed the steering gear for nothing, since this was the problem I was trying to solve.
What is going on?? Is there something inside the steering column itself that could be loose/worn out? Or is this normal, and my expectations are just unrealistic?
Old May 18, 2014 | 05:57 PM
There is a Cross Shaft Adjustment procedure but I would hold off if both gear boxes are doing the same thing I'd be looking at all steering and suspension components.
Worn Ball Joints or Control Arm Bushings can produce loose steering feel.
Old May 18, 2014 | 07:07 PM
Paladex's Avatar
Thank you ... I will check the ball joints and control arm bushings. Anything in particular I should be looking for?
Does it change anything if I point out that the wheel response is the same whether the car is stationary or moving?
Old May 18, 2014 | 07:23 PM
I like to have a friend turn the wheel back and forth, not lock to lock, just like 1/8th each way.
I crawl under and focus one connection point at a time, 2-3 back and forths for each one. If any one shows movement make a note, then raise the car at the proper spots to check individual components.
Old May 18, 2014 | 08:58 PM
Check the flexible rag joint between the steering box & the firewall
Old May 19, 2014 | 06:10 AM
Paladex's Avatar
Will do. Thanks!
The Dustman
Oct 5, 2012 09:10 AM
bltpls5
Nov 19, 2010 02:52 AM
philhrc
Jan 6, 2009 05:28 PM
naughtyus maximus
Jul 3, 2008 03:22 PM
jane1043
May 6, 2008 07:01 PM
