Proper spark plug handling
Old Oct 30, 2017 | 09:11 PM
dodgem880's Avatar
I was doing some research and stumble a cross a post that mention how spark plugs should be handled.
Make sure they are properly gapped,
DO NOT Pry on the center electrode to gap them!
DO NOT bang on the 'Ground' electrode to close up the gap!
Modern 'Resistor' plugs are VERY SENSITIVE!
Use a pair of NEEDLE NOSE pliers to bend the 'Ground' electrode instead of PRYING on the center electrode! That's the WORST thing you can do to a spark plug (Prying on the center electrode or 'Tapping' the gap closed!)
They have a 'Carbon Pile' resistor inside the insulator, and if you break that very fragile carbon, 1/6 of your horsepower and torque goes right out the window!
IF YOU DROP A PLUG ON THE GROUND, REPLACE IT!
I can't stress this enough!
This is probably the #1 reason for 'Loss Of Power' or 'Poor Economy' complaints after a 'Tune Up'!
People just don't realize how fragile the plugs are!
You don't need a ton of 'Never Seize' on the threads, but you DO need to use it (Copper if you can find it, but zinc is OK if you can't turn it up easily or Copper is too expensive for your project)
Is that right? I'm pretty much guilty of all of that.
The pry and tap stuff. I always figured it was bad to drop them, but didn't think it was a automatic death sentence for the plug.
Anybody heard of this?
Old Oct 30, 2017 | 10:59 PM
Drag Pak's Avatar
All true!
Old Oct 31, 2017 | 05:40 AM
Archer's Avatar
d -
Sure, but take it with an ounce of common sense.
Old Oct 31, 2017 | 03:55 PM
Drag Pak's Avatar
Originally Posted by Archer
d -
LOL. Yes, but how common is that!
Old Nov 1, 2017 | 11:20 AM
dodgem880's Avatar
Alright then.
Learned something new.
Thanks
Old Nov 1, 2017 | 04:12 PM
Old news but I'm glad it's getting out!
rcknrolfender79
Oct 17, 2017 03:55 PM
buttton
Apr 1, 2013 10:00 AM
austin
Sep 18, 2012 12:37 PM
nrand
Jul 11, 2012 03:52 PM
nrand
Jun 26, 2012 03:29 AM
