Slant Six Timing Way Off
Old Aug 19, 2019 | 03:47 PM
Scamp72's Avatar
My 225 slant six Scamp's timing mark is way, way off (if the mark's at 10:00, my timing mark is at 2:00) but engine runs perfectly.
Any idea how/why this could be?
Old Aug 19, 2019 | 06:36 PM
The outer ring of the harmonic balancer has broken the rubber bonding and slipped.
Old Aug 19, 2019 | 09:06 PM
The balancer must be replaced as soon as possible if not sooner. It can and will come apart causing damage to anything and everything including you if your working under the hood at the time.
Old Aug 20, 2019 | 07:29 AM
yeah, they are known for slipping that outer ring. only way to time my fury was by ear. use a gun and it sounded like a harley on rubbing alcohol.
Old Aug 22, 2019 | 06:11 AM
Scamp72's Avatar
Thanks all. We wondered if it was the rubber piece. Would this also cause the pulley to look askew from the side? Thought that seemed weird as well.
Can it really fall apart?!
Old Aug 22, 2019 | 08:23 AM
"Fall" apart isn't really the correct terminology. They'll violently explode apart — so yeah, i'd replace it asap or have a knowledgeable guy at least take a look at it and confirm or deny.
Old Aug 22, 2019 | 02:12 PM
Scamp72's Avatar
Gotcha...scary. Thanks for the heads up. Any chance it could just be missing a damper bolt?
Old Aug 22, 2019 | 02:40 PM
No, not with the timing marks off like they are. This is classic Chrysler.
Old Aug 22, 2019 | 04:37 PM
Scamp72's Avatar
Ok, thanks very much. Guess I've got some work to do
raceware
Mar 31, 2016 05:32 PM
champer
Sep 3, 2014 02:43 PM
Dave E
Apr 3, 2014 12:38 PM
MrCoronet
Aug 19, 2012 08:55 AM
Dartingtraffic
Oct 15, 2011 06:17 PM
