Speedo Gear Question
Old 12-02-2008 | 03:08 PM
Is this for the 65 Belv?
Old 12-06-2008 | 09:43 PM
challenger's Avatar
im pretty sure you can buy the kit and it will have different color gears in the kit , i cant remember off hand how to config: it but there is a way and ill look into it for you just give me a day or so
Old 12-08-2008 | 09:26 PM
challenger's Avatar
hey a GPS is more accurate then a speedom but i understand and im still getting it together for u .... at least im trying but ive ran into some of my own delemas for the moment but will get back to you asap
Old 12-08-2008 | 09:28 PM
challenger's Avatar
forgot to ask, what trans is in your car thanks
Old 12-11-2008 | 08:40 PM
challenger's Avatar
hey 65Azbel the beast i can come up with is a 33 tooth gear which is a yellow one... do you have an email address you can give me and ill send you a chart and then you can also go from there ok
the part # is 2538933 for a standard style pinion gearing
Old 12-12-2008 | 12:08 PM
Crazy4Carz.Com's Avatar
Here is the complete answer. Save this chart so you have it in the event of a rear gear swap or tire size change.
http://www.yearone.com/yodnn/tech/Te...5/Default.aspx
Old 12-18-2008 | 11:09 PM
challenger's Avatar
open the hole and jack the car up then take a red marker, mark a tooth and turn shaft and count the teeth, its the easiest way i know
Old 12-23-2008 | 07:05 PM
challenger's Avatar
have you made headway on the speedo
Old 01-01-2009 | 05:29 PM
deadkelly's Avatar
Question
do 904 & 727 use the same speedo drives ?
Old 02-10-2009 | 02:30 AM
johnthegoalie's Avatar
thinkin with me dipstick
also a little tip, when installing - on the housing there are markers for how many teeth on the gear you are using - line the appropriate one with the marker on the tranny itself.
74Runneer
12-07-2013 03:16 PM
maca
01-31-2013 06:26 AM
AV8AP6
04-01-2012 05:19 PM
Cazbah362
03-19-2012 04:52 PM
stazja01
06-02-2009 06:45 PM
Quick Reply: Speedo Gear Question
