Speedo Gear Question
Old Dec 2, 2008 | 02:08 PM
Is this for the 65 Belv?
Old Dec 6, 2008 | 08:43 PM
challenger's Avatar
im pretty sure you can buy the kit and it will have different color gears in the kit , i cant remember off hand how to config: it but there is a way and ill look into it for you just give me a day or so
Old Dec 8, 2008 | 08:26 PM
challenger's Avatar
hey a GPS is more accurate then a speedom but i understand and im still getting it together for u .... at least im trying but ive ran into some of my own delemas for the moment but will get back to you asap
Old Dec 8, 2008 | 08:28 PM
challenger's Avatar
forgot to ask, what trans is in your car thanks
Old Dec 11, 2008 | 07:40 PM
challenger's Avatar
hey 65Azbel the beast i can come up with is a 33 tooth gear which is a yellow one... do you have an email address you can give me and ill send you a chart and then you can also go from there ok
the part # is 2538933 for a standard style pinion gearing
Old Dec 12, 2008 | 11:08 AM
Crazy4Carz.Com's Avatar
Here is the complete answer. Save this chart so you have it in the event of a rear gear swap or tire size change.
http://www.yearone.com/yodnn/tech/Te...5/Default.aspx
Old Dec 18, 2008 | 10:09 PM
challenger's Avatar
open the hole and jack the car up then take a red marker, mark a tooth and turn shaft and count the teeth, its the easiest way i know
Old Dec 23, 2008 | 06:05 PM
challenger's Avatar
have you made headway on the speedo
Old Jan 1, 2009 | 04:29 PM
deadkelly's Avatar
Question
do 904 & 727 use the same speedo drives ?
Old Feb 10, 2009 | 01:30 AM
johnthegoalie's Avatar
thinkin with me dipstick
also a little tip, when installing - on the housing there are markers for how many teeth on the gear you are using - line the appropriate one with the marker on the tranny itself.
74Runneer
Dec 7, 2013 02:16 PM
maca
Jan 31, 2013 05:26 AM
AV8AP6
Apr 1, 2012 04:19 PM
Cazbah362
Mar 19, 2012 03:52 PM
stazja01
Jun 2, 2009 05:45 PM
