Starter motor stays engaged
Old Aug 12, 2012 | 09:01 AM
70newport's Avatar
Hey guys so I recently replaced my starter motor on my 383 and since then when i start the car the starter motor stays engaged for 2-3 seconds after it has cranked over and fired up. Any suggestions on how to solve this?
Old Aug 12, 2012 | 10:20 AM
May be a defective starter, except this symptom would seem rare
Make one test to be absolutely sure it is not electrical (caused by other problems)
Disconnect the battery ground for safety.
At the starter relay, disconnect the wire going to the "square" screw terminal, IE the only screw terminal, not the stud. Pull this wire safely away so that it's not making contact.
Reconnect the battery, turn the key to run, and be absolutely sure the car is in park or out of gear if a stick.
Then crank and start the car by touching this wire to the big stud on the starter relay. If the starter still remains "sticky" as before, turn it in for warranty.
Old Aug 17, 2012 | 10:13 AM
70newport's Avatar
So I tried what you suggested and asuming I did what you were wanting me to do the starter did the same thing where after hearing the engine fire and taking the wire away from the stud it stays engaged for 2-3 seconds. it does not grind at all like if you try and start a started engine you can just hear it labouring and spinning still if that makes sense...... if you would like me to take a video/audio clip and e mail it I can do that.
Thanks for the help.
Old Aug 17, 2012 | 12:54 PM
MrOldart2U's Avatar
Maybe just a crappy rebuild and a noisy "run-down". My autozone reman starter on my volare is rather noisy, but doesnt really hurt anything.
Old Aug 17, 2012 | 01:37 PM
I have seen someone replace the starter relay only to have those two wires barely touching and the starter would continue to crank away.
Old Aug 17, 2012 | 01:41 PM
Sounds like a defective starter to me
Old Aug 17, 2012 | 01:42 PM
I've had this happen to me, I loosened the mounting bolts and pulled the starter away from the flywheel and retighten.
Old Aug 19, 2012 | 10:39 AM
70newport's Avatar
I tried this and it did not change anything. Im guessing my next step is pull it off again and take it in for warranty.......
Thanks everyone for the help.
98 SNAKE EATER
Nov 15, 2013 06:32 PM
kiwi
Jul 9, 2011 01:34 PM
anthony oborny
Jan 10, 2010 06:06 PM
Hot69hardtp
Dec 30, 2007 06:21 PM
sgoffena
Nov 9, 2007 07:55 PM
