Starter Question
Old Sep 11, 2019 | 09:45 AM
RjWinslett3's Avatar
Starter Question
I'm pretty sure it needs to be replaced but I have a 74 plymouth satellite with a 318 and the only way to start it it to basically jump the starter solenoid. Would I need to replace it or could it just be wiring?
Old Sep 11, 2019 | 09:53 AM
There cheap enough but it could be the wiring coming from or the ignition switch.
Old Sep 11, 2019 | 09:57 AM
Is it easy to replace the wiring? This is my first mopar so I just wanna make sure I'm in the right direction
Old Sep 11, 2019 | 02:18 PM
If your starting it jumping to solenoid. the problem is not the stater.... You ether have a ignition switch, wiring, safety switch issue....
Old Sep 13, 2019 | 03:42 AM
xaza's Avatar
cheapest thing to start with is the starter relay. You can borrow another relay such as AC sometimes and just swap them to see if that resolves the problem, not sure on your specific car what relays you have. Just look to see if there is another relay same as the starter in the relay box and swap them. Other than that it could be ignition switch as Bob said. The other culprit I deal with on my rigs is the neutral safety switch on automatics. Try shifting to neutral instead of park and wiggle the shifter as you are trying to start it.
Old Sep 13, 2019 | 07:22 AM
Exactly. Don't pull that heavy starter for no reason.
66FuryBoy
Jun 13, 2022 08:48 PM
86dodgew150
Sep 23, 2013 08:00 AM
Salty
Jun 4, 2012 04:18 PM
AZDODGEMAN
Apr 11, 2011 12:39 PM
prive81
Aug 3, 2010 06:50 AM
