stripped spark plug/heads
Old Dec 8, 2010 | 09:48 AM
Gordy49's Avatar
I have alummnum heads on a 383 dodge charger and have stripped the threads on the spark plug holes. i am using champion rc12yc. 3/4 inch reach. What is the best approach to repair this. Gordy
Old Dec 8, 2010 | 11:50 AM
rdrunner1974's Avatar
Plug repair
It's posible to repair. Use an insert type. Removing filings will be a challange. best to remove the head ('s) and have a machine shop perform the job.
http://www.denlorstools.com/home/dt1..._spark_pl.html
http://www.helicoil.in/pdf/HeliCoil%...onal%20Kit.pdf
http://wiki.answers.com/Q/How_do_you..._plug_helicoil
Good luck
Old Dec 8, 2010 | 01:40 PM
condor74's Avatar
you can do it on the car as mentioned above it is better to remove the head and have a thread insert installed. If you do it on the car metal shavings will fall into the cylinder..You can catch some by keeping grease on the end of your tap but too risky for a car like that.
Old Dec 8, 2010 | 05:40 PM
scotts74birds's Avatar
Depends on how far you went. There are specific "spark-plug thread chaser/cleaners" out there. If you just boogered-up the first few threads, then I say the chance of success with one of these is pretty good! http://www.sears.com/shc/s/p_10153_1...u=00947321000P Btw, when I googled this, there were dozens of thread repair tips. "spark plug repair" I did this once on a girlfriends 2.2 Omni. This tool allowed me to "save face" and fix it cheap and easy. Kinda like the girlfriend! HAHA!
Nomadci
Jul 10, 2010 06:18 PM
H-Pattern
Jun 9, 2010 08:09 PM
sweeperking
May 26, 2010 04:34 PM
May 17, 2010 08:32 PM
will d
Feb 13, 2010 06:33 AM
