swapping 93 magnum into 83 ramcharger
Old Oct 6, 2019 | 03:25 PM
delsolsi1980's Avatar
i am swapping a 93 magnum out of a dodge van into my 83 ramcharger. what I'm looking for is information as to what wires i need to make it run and what wires are for ignition, fuel pump, oil press, coolant temp etc. if worse comes to worse ill fab a new gauge cluster and use manual gauges. I thought there would be more information out there. i plan on using o.e wiring for the body lamps and such
Old Oct 6, 2019 | 03:42 PM
The best way would be to get as much from a 93 pickup as you can and use it. Wiring harness dash etc..
Old Oct 6, 2019 | 03:53 PM
i agree, that would be great. but i have the van sitting here with a low mileage engine
Old Oct 6, 2019 | 06:46 PM
Then your going to need the wiring diagram for both vehicles to blend everything together.
Good luck with your venture, Tom
Old Oct 8, 2019 | 07:11 AM
What he said..... Keep us posted.... Sounds like a fun build....
Old Oct 8, 2019 | 08:04 AM
I went LA to ‘92, opposite of you but what I found was you’ll want the computer with all sensors, trans, fuel tank/pump and the gauges. The LA doesn’t need the computer to run or charge but the gauges/dash to run the truck.
In your case removal of the gauges will mean removal of all the electronic sensors and at that point the electric charging system won’t work as the voltage regulator is in the computer and needs engine input to function.
Chase
Dec 5, 2017 09:28 AM
peder
Aug 10, 2017 11:36 AM
Leg Humper
Jan 19, 2016 06:08 PM
ramchargerguy
Jun 30, 2012 09:03 PM
mschoppe35
Jul 30, 2010 05:55 PM
